who?
the two fat bishes?
one just looks really dirty, like throw up dirty. i think deena or diana or something.
Yeah deena, she's the one that says do you like the boobs and 'I wanna do sex'
Pretty much all 4 of those bitches are ugly skanks, only watch it coz Pauly is a funny kunt
pauly and Vinnie?
Ron is the big guy lol there was an episode where him and sonic got into a fight and sonic put his own head into the contrete wall and gave himself concussion.. in italy. i was pissing myself.
its just one big problem, probably the only funny reality going around
dude your tamil, you will have a full grown moh by todays end. lol
funnily enough, this is as far from the truth as possible. i struggle to grow facial hair. im a weird kinda tamil
you know if you raise $40 you get free grill'd from 2pm to 3pm?
what the hell makes you think im not aware?
there was an episode when ron knocked out some guy after a club and went to jail. i lold at the guy on the floor having a fit
Is the rest of the season in Italy any good or crap? Is it still going?
Kinda switched off it because it got boring.
dunno the missus downloaded the season.. just watched it with her.. its pretty funny man.
sonic(the situation)
gets;
wine bottles
fists
spatulas food
plastic cups
thrown at him.. no one likes him lol
its just funny n it passes time dude lol
And from 8:00-9:30pm. Take this knowledge with you and prosper my son.
Damn that RX-7 keeps going up. Need to contact the owner and see if I can invest some shares in it.
lol, just saw new notes added to the listing that say "new clutch and new tires" will be fitted. Hence the $2500 jump in price. I assume he's fitting Pilot Sport 2s and a cushion button...that or he thinks you should profit from repairs to a car that wasn't functioning properly in the first place. Dodgy fucker.
Hottest 39 year old in the world. Show is kind of funny too.
win - every time i watch it i get asked the question by the missus "are you just staring at her boobs" I quite happily say f**k yeah
More of a doco re oil rigs in texas
ohh yeh i remember the show.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
