famous because we program
worldwide Let'em recognize from long beach to rosecrans
bumpin and grindin like a slow jam
its west side so you know the row won't bow down to no man
California.
Knows how to party.
California.
Knows how to party.
Say what you say
But gimme that bomb beat from Dre
Let me serenade the streets of LA
See u Aaron :P
were you doin prinny as well?
i got tailed by a hwy patrol for a good 10 minutes.. i was lucky as some douche in a commodore ripped a skid, he got pulled, i went straight home lol
Some guy pulled a blade inside Pretty Please...six squad cars came and f**ked his shit up...who brings a knife to a nightclub? Clearly looking for fights.
Maybe he was gunna shave? To much underbelly for him
