do it yourself
its pretty easy
theres even howto's in the howto section on it
the paint costs about $40 tops and some shitty sandpaper
to do the writing differnt colour paint the calipers one colour with vasoline over the lettering
then when its dried and done, wipe the vas off and reverse to do the lettering
Grad accountant who I extended the probation period for has spent 1/2 and hour trying to open a file but couldn't and is asking me why.
All she need to do was to unzip and extract the file
An accounts girl we employed doesn't know how to use Excel...fark.
If I got given that... Sell it, buy s2k = 50k+ to play with
I think I know the owner of that, if it is then her dad works for Porsche Australia and had it de-tuned so she could legally drive it on her Ps.... What an 18th present though :rolleyes:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
