Re: 335i I loved them until I realized they don't come with a LSD need an M for that. 1M is a great car, won't say a great buy just yet until you can pick them up 2nd hand cheaper.
I'm tryin to hold off from a new car until jan next year, that would mean I can get a 11' plated with a decent ammount off? Looking at fpv or hsv at this stage if it makes any difference. But yeh a bit lost on the best way to go about buying a new car.
Edit: yes I'm wanting a v8 for a change of pace :) hopefully not too far off imports haha
Purchase outright, maybe an ex demo if it's like 7k+ cheaper than what I could get new at the best price. I guess what I'm asking is it worth me waiting till jan ? Or will it be stuff all saving compares to say early dec? Then at least I got a car for Xmas time
So Ex demo car 7K saving + 1 month earlier v New car
How much do they go for 2nd hand? Aren't ex-demo's generally thrashed? Correct me if Im wrong.
Also make sure the 'new car' price is the driveaway price, and does not have other hidden charges.
Do you have alot of time off work during the x-mas period and thats why you want it before then?
Edited by blah_blah
just what i saw, cant remember which ep of top gear, but they all chose the 370z over the m1
said it was a better car overall and the price was the last straw in the decision
yeah not to sure on exact figures
but i know 370z ain't no slug
I have no idea what video you are talking about??? The 1M bet the M3 around the topgear test track.
I think you are talking about 135i vs 370z...
edit: read through thread. S'all good.
come again?
you put a brake line clamp on the soft line near the caliper to stop air get in/oil getting out, less of the system will need rebleeding when you reattach the calipers.
<cool story bro>
Pulled up at lights, heard someone talking, look to my left. See a 60yr old guy in a new toyota camry looking at me. I said "sorry?" as I missed what he said. (im thinking he said some hoon comment about the car being too loud or something). He replies "nice car" and keeps mirin my car...
It seemed so out of character for him, caught me off guard.
Majority of times cars next to me always stop short of my window and other import drivers just look dead straight :(
Thumbs up to old guy :thumbsup:
</cool story bro>
<cool story bro>
</cool story bro>
csb bro Did he give his camry a boot?
We're you the skyrine that was driving behind me on springvale road when we were all heading home and I turned off a bit after Princes Hwy Saturday night?
lol smart jpg change.
Kott daymmnn shes hot.
How are the ladies in the land of U S of A?
