Good thing about commercial/industrial is they get you doing actual work straight away where as in domestic unless you're working for a relative or friend you're basically a labourer for the first year or so doing just the crap stuff like digging, cleaning up, getting tools etc.
You start tafe next year yeah? Hope you like using the reg book lol
Always heard the opposite, that you get lost in big companies and end up being a cleaner/labourer for the first year, whereas in domestic you get thrown straight into wiring up houses coz it's just u and the boss or 1 a grader etc. But yeah so far it's been good, the other guy that started with me has been cutting/filing cable tray so I'm sure I'll cop that soon enough. Gotta be done.
And I read AS 3000 before bed
yeah maybe if its just you and the boss he'd have no choice if he has no other more experienced apprentices but most of em dont wanna waste time teaching while working just want you there as an extra pair of hands
Cute
Holy f**k Twin Turbo 300ZX's are cheap!!!
Having to pull out all the drivers side intakes and shit to get to the PS lines/pump 5 or so times did my head in but now for some reason I want one, Stockholm Syndrome?
Never filed cable tray before, makes sense though I guess haha
I'm a 2nd year at a domestic/industrial/commercial company. Mainly doing bunnings stores at the moment.
Small company = learn more
Big company = earn more
Depends what's most important to you IMO, I get the bare minimum award wage, but I learn a hell of a lot more than people I go trade school with who earn a fair bit more than me, but it's an apprenticeship so I'd rather gain as much knowledge as possible and then earn more than them in the long run haha
Summer is just around the corner. Shoulda started a lil while ago lol
I'll take a tray load. no homo.
Yeh I did start about a month or so ago, don't get me wrong I'm definately seeing results just want that little bit more, I guess I gotta work that little bit harder and eat that little bit better / more. Guess there is no tricks for speed other than that or roids as Alex said :P but then you get shrinkage amirite?
and after replacing all the balljoints and bushes on one, it ain't gonna be cheap anymore.
Dunno still as large as ever ere
Agree and disagree...
Not just a case of 'what's most important', for some it's a matter of what they can/can't afford to do. I'm 25, almost 26, and have a mortgage...So domestic/small company/non EBA is out of the question for me. Sure you might learn more to begin with, and probably wire neater, but it evens out in the long run (got mates in domestic, mid size companies and the big boys) after around the 2/3 year mark everyone is pretty much on a level playing field...At the end of the day you'll learn as much as you want to learn. I know I've only been there 2 days, but I can tell the guys I'm working with are happy to teach me as much as I want to learn, and aren't just using me as a labourer.
As for the pay side of it, a 3rd year apprentice on an EBA job makes more than a domestic A grade, so unless you own the business or you're doing work on the side, there's no comparison in the pays.
My mate is 3rd year and on $40 an hour....
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
