If global economic climate doesn't improve I think these unions will have priced themselves out of jobs my mates who run the major sites are not getting any work laying kents off left right n centre it costs to much to build in Victoria sure u get the odd cash cow west gate / desal plant when it's good it's good but I had mates on west gate before that no work for 6 odd months was doing handy man shit to keep busy and earning
+1. Same applies for manufacturing industry. Try competing with China production, they dont have unions to worry about :/
Lol "healthier" neither is healthy but shisha smoke is cleaner than cigarettes (filtered, less tar, etc) the thing that makes shisha worse is much longer smoking sessions, who's counting the puffs...
dont inhale and you'll be fine.
http://news.bbc.co.uk/2/hi/8214097.stm
not the kinda people i'd wanna sit down and chat to...
in that case you should have seen the bogan at the trailer park village at the nats that kept coming out and talking to us LOL
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
