knob shiner tyre fitter scratched both my freshly powder coated rims on the front not to mention the raping of the back lip
least i know not to take the other 2 there when they're done
inconsiderate f**ks
Is it noticable? What did the guy do about it?
Yeah got it, haven't had much time to play but it's good. Would be even better with a wheel/cockpit setup
yeh fair enough looks decent in the promo's
@flynn if only you knew you, her & her family are worth a shit load more than me so dont rkn she gives to fks. But keep clutchin at straws man im sure you can google some more internet gifs that are suppose to be funny.
or post more chicks that wouldnt even fart on you let alone consider being with a pathetic loser like you :thumbsup:
But he likes guys that have 'style' and aims to dress just like them Alex...
QTF.
rimon make em fix ya wheels man.. i was really paranoid when gettin tyres put on the kranze's but they did a top notch job, looked like the dodgiest place ever haha
please stop adding me to facebook wasteland chat
if i want to chat i will do it in here
We're not adding you, it just pops up when there is a message and your facebook chat is online. Stop it from popping up by doing this:
Pops out of no where when message has been sent in it. To open it just click The Wasteland under Groups on the left, and the chat will open. But your facebook chat needs to be online to chat in the group. Lol.
Means you dont appear to be online to me, cause we're not friends on fb. :O
Ah I see.
how do you'ze even chat in it? it just pops up out of nowhere for me :unsure: not down with all this fancy facebook shite
Sometimes it does to me, sometimes I have to click on wasteland group.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
