Go get the X-Ray first Grant, the dentist can then use that to assess what it will cost. I've been procrastinating my X-Ray for about 6 months now...it's just one tooth and it rarely gives me trouble painwise, but the f**ker has come in completely on side (as in the top of the tooth, the part that chews, faces towards the opening of your mouth!). Only concerned about food getting trapped there and decaying other teeth!
didnt read all the replies but grant got a really good dental surgeon for you.. Dr j w ferguson in box hill.. Ill send u his details tomorrow.
Not sure if u need a referral, pretty sure u do.. Will need to get a periwing xray or whatever at dentist, then get a full xray at a radiology place.
I still have one impacted wisdom tooth but its not causing me any dramas atm.. But then its amazing how you can live with pain sometimes to the point u dont notice its there.. Til its gone..
Will get into it ASAP. Mine is just growing inline with my bottom half, it's pushing along the gum and another tooth, causing all the pain.
Thanks, shall wait for your PM/message, mum is going to ringing bunch of dentists today for me.
http://www.heraldsun.com.au/news/kmh-hoons-car-impounded/story-e6frf7jo-1226194180711
After eight people were killed on Victoria's roads on the weekend, the 19-year-old man was detected travelling at 146km in a 70km zone at Hoppers Crossing.
Police intercepted the Nissan Skyline on Old Geelong Road near Costa Drive around 8.20pm.
The Hoppers Crossing man had his car impounded for thirty days and is expected to be charged with traffic related offences at a later date.
Box Hill, that's a long from the west side!
i wasnt think of anything, thats why I asked?
couldve been;
"a long, but good walk from the westside"
"a long, flight from the westside"
"a long, seven from the westside"
i'm in the biggest smartass mood today. lol i've already corrected my boss 3+ times
Have a dude keen as on my rims.
Can I borrow someone's stockies for a couple weeks till I get new rims? Lulz.
Inb4flamin mongrelstellmeiahouldnthavesoldmystockies
we should give you four space savers lol
couldve been;
Since your on a roll and a DJ, what program are people using these days to download individual mp3 songs?
I've been out of the game too long...I have no idea
legally?
itunes.
ilegally
a lot of people will just download an album, when they need a song off it.. its how they get more music than what they just know.as a torrent through frostwire or bitorrent or something.. either either..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
