f**kn kadz. i swear you are the biggest dick head and should be euthanised
We just need to accept that some races as a whole are just better than others. As an individual you might be cultured, educated than the average Joe but can you say the same for the rest of their fellow countryman? Doubt it.
However, Germans as a whole are just supreme beings :)
For instance, Arabs can ONLY become something when goat lovers lead them or take over, as has been the case since 900 a.d.
No offence Mohsen. As an individual you're a top fella and 100% better overall than the rest of your fellow countryman.
Edited by Flynnn
33/34 Hicas is electronic... No crappy lines to worry about like 32's ;)
There is actually a DIY on here, it's not hard to do at all.
Knew I should have bought a 33 four door instead. Stinkin 32 haha
Billy come do mine for me if it's so easy haha
As much as I would like to
Disagree, you are partly right. I won't bother explaining.
But I do look forward to the upcoming Israel and its little bitch v Iran and Syria war ;)
the sphincter of the universe is no position to ally with Israel when it has been condemning the state for the past few years, not to mention the flotilla incident last year.
This isn't Iran's business either so i very much doubt Iran would get involved considering its busy fighting off (politically) or preparing for a possible attack by US.
There might be a high possibility that the sphincter of the universe just might move in, militarily, to free the people from the brutal Asad regime/dictatorship.
The land of goat sphincter rings military is already preparing as quoted by CNN
http://www.youtube.com/watch?v=i-6aGfW76ck
Brutal? Not at all mang. Keep believing the western propaganda.
It isn't the government v the people. It's Islamists v the government.
Family in Syria has confirmed this.
Btw, if you want to discuss this, pm me, let's keep it off the wasteland.
will be next year some time. i will definitely!
I asked Luke Youlden to take my car for a couple of hotlaps to show me the potential. (he was one of the instructors on the day) Opens up your eyes to what your car can do with a pro driver who has nothing to lose haha
Long story short, brake fade and melted my dust boots in the calipers :( haha
f**k lol
i'd just like to put it on the track, maybe i could learn more about this car!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
