stock BCNR33 is a round 160/170 rwkw
dont forget its rear wheel drive until the system detects traction loss
so technically its a rear wheel drive car until loss of traction
its not like an evo where its always all wheel drive with adjustable split
Found this in the dyno thread:
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page__view__findpost__p__5448314
1995 R33 GTR - 110,000KMS
Stock everything except splitfire coilpacks.
stock boost.
193.4awkw
Every dyno is different but interesting none the less.
Why are you both calculating it as rwkw instead of awkw, since a gtr is 4 wheels?
Cause most dynos are RWD and I think the GTR boys usually pull their front driveshaft for tuning/runs.
Figure sounds too high, either happy dyno or he has an exhaust / aftermarket cooler / boost tee. The factory flywheel kw was supposed to be 206kw, but more realistically ~220ish which is around 160-170rwkw.
Ok found another one, close enough to stock
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page__view__findpost__p__5121848
1995 R33 GTR
107xxxkms
kakimoto catback
everything else stock!!
First run in red was with boost restrictor pill still in place!!! About 170atwkw
Second run removed, 30atwkw increase pretty good in my opinion!!!!
30awkw increase by removing the boost restrictor! What are you waiting for Grant?
I got 233rwkw with just an exhaust / boost restrictor removed / cam gears @ racepace dyno (stock ecu)
GTR was just fail to get to work in imo, maybe I'm soft but thats pretty much all it got used for haha
Money.
For pair of steel wheeled turbos, PFC, injectors, afm, exhaust, labour money to fit these plus nismo clutch I've got sitting in garage for a while.
And many more things such as swaybars, arms, tyres for the rims, alignment, hicas lock bar.
It doesn't end!
ok the lease rules are oldest model allowed is 2007/2008
only found evo ix 07 which is like 40k pfft
where is nick he will know of a 2007 IX for cheap
Just a question Paul. Why Evo?
Doesn't that feel like you're downgrading from a superior 6 cylinder to a inferior 4 pot?
No offence to Nick :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
