Wah wah.. and f**k its not my problem the bish has a boyfriend?
if you want I can tell her again, but you dont want to come off needy do you now.
I wanna go garage cafe never been where all our invites
You said she didn't have a boyfriend...or that it was shaky...you promised me shaky. Nah don't tell her again, that does sound desperate, I just thought you were hanging out with her soon and you were gonna ask her on my behalf for a date :)
Get a gixxer
Fffffffff sore spot ;)
Get a gixxer
I already have one!
Good day sir.
Thats awesome. Never seen a girl on a track with a bike before.. srs.
I want a bike now :)
Doo iit. I have a fluro yellow helmet on the way and am stickering the fairings in fluro red and yellow in a Tron Light Cycle inspired design of course! Can't wait to finish it and have my own Light Cycle :wub:
we are soon i guess. i havnt needed money lately so i havnt bothered chasing it..
nah new pics of her keep arising with some skinny indian flamin mongrel so im assuming shaky is now settling
whos going to garage cafe from the SE?
It's not about needing someone else to do the work for you ya dick, or them doing all the work for you (for that matter), ever heard of a wingman? If it was someone I knew and had met before then there wouldn't be a need for it, tis not the case.
You can be my wingman anytime Maverick
i duno the guy looks like a scrag. and you know what type of guys good girls look for nowadays.
Skinny fucks with a pink T-shirt, tight jeans and a bad haircut?
Couldn't believe that either when I read about that...pretty amazing how tall it is in first...100 would have sufficed!
My friend wrote his off 2 weeks after buying it brand new, hit a patch of gravel on the road and he was gone :(
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
