you need a 200k r8 for that? :huh:
probably not 200k for them
Is it black or dark blue? With bright-ish headlights?
what is this bright headlights you speak of? like they light things up so you can see? amazing!
Yeah dark blue.. wasn't a mate of yours was it? If so, sorry about the top bloke call lol
Ah yeah, seen him around, dubt he'd wanna be mates with a bloke who have purple datsun...
So...who repping at the Show 'n' Shine this Sunday? And who coming down for a looksy?
ME!
Providing I can find a parking space...
Yes amazing, by Lamborgini Countach standards....
...it has HID's, hence brighter light for '70/80s car.
A parking space? You aren't putting your car on display?
Yeah, I'm putting it on display whether it's dirty or not.
By parking space I mean, park in the 'parking space' for the SnS.
There's plenty of space, remember last time? We had to space out the cars to make it look bigger lol. Should be a bigger show this year with better expected weather.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
