Because 380 is HUGE power, not just big power ;)
Its also a massive % increase for just a tune
Lol have you been in a boss model yet? My manager has one and they absolutely hammer.. Didn't actually believe ford brought out such a powerful car from factory in AUS
380rwkw without mods? :mellow:
what do they weigh?
About 1800, maybe a bit less which is expected I guess for a big car.. got about 300kgs on my old GTR :O.. still do a tune and your in 11s.
Other vids online to back this up as well / all info on forums etc
Standard boost just drops off so much
They go alright:
This ones got a catback and a tune, nothing else
I met a bloke the other day selling a Callaway Corvette..90k if anyones interested..still left hook though
11 sec in stock trim and 200mph+ top speed
much the same as this one
http://www.youtube.com/watch?v=x8HyT4d7Kzc
Enjoy 380rwkw on pos stock tyres/suspension/brakes
When you bringing it to a meet Leigh?
Obviously upgrade the 245s, and will be doing brembos / suspension down the track as well
Whenever the next meet is !
Saving for a few months, what are they made of gold? Get a Blitz CS and stick with the standard plenum...
Lol studying full time+part time wages=not a lot of cashola.
Yeah I've read that that upgrading the plenum on a standard turbo isn't really worth it as I won't see any real gains but by doing it now with a FMIC it means I won't have to do it down the track and it'll support future mods better (ie. upgraded turbo). What I liked about the plazmaman plenum was that it retained the standard factory runners. Essentially I'm not after a car that's a dyno king rather a quick car with some good midrange torque.
interesting leigh!
the car was running 118's @ full weight, anyone know enough about boring/pointless/homo drag racing to derive a rwkw figure from that?
FWIW i ran consistent 119's with 325rwkw @ 1350kg
Going by that post, you do not need a plenum upgrade and are only wasting your money if you get one. And it doesn't sound like you have a big disposable income so why bother?
If you're not after a dyne king, rather a fast street car, turbos like a gt-rs are where you'd be looking, and you don't need an aftermarket plenum for that.
If you ever decide to get a turbo that does warrant a plenum upgrade, thats when you buy one...
interesting leigh!
What about that fluke 190mph pass Ham? No need to be modest
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
