Jeppe, how much for 40ml of stana?
Haha, sorry dude, only have penicillin and this apple flavoured stuff. Although I can get sedative for when I clip the horses in winter. I'm guessing though because I can administer it myself it's not the good kind. Will probably kill you.
"jeppe" = dutch?
Dutch as a first name, switched to last name when my ancestors entered South Africa :)
I think you'd need more than a litre to trim down momo
lol can you imagine someone taking a liter. imminent death
clen.
Tasty
Would you get one though? Must admit they are good value. Guess that's why there are so many of em on the road...
I also like the hsv coupe but dunno something about owning a holden always puts me off buying
Yeh I agree rimon feel weird if I had a holden but to get same specs engine wise in a prestige brand your talking like double to triple the price he holden interior wouldnt compare to a prestige car but I guess your really just buying the motor..
Agree Dezz I been slack went gym once in the last week! They called me yesterday offering a 12 month membership for $12p/w but none of my mates wanted it
Tasty
Agreed, consider that a well kept E46 M3 is going to be up around that and the performance is basically the same, with the HSV being newer and much more car.
HSV Coupes still look good IMO. I'd love a Coupe 4.
And owners want RRP for them lol.
Reminds me of those cocksuckers you see when looking for cars, who have the previous model of a car and are selling it for the price of the next model up because it's "so well kept"...in other words they want a model upgrade for free.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
