This dim-witted sloth is the worst excuse for a human-being. Not only does he lack the skill to express himself, he also has tourettes
i'll take the bait... ratemyteachers... why?
Noun 1. dimwit - a stupid incompetent person
doofus, nitwit, half-wit
colloquialism - a colloquial expression; characteristic of spoken or written communication that seeks to imitate informal speech
simpleton, simple - a person lacking intelligence or common sense
Noun 1. sloth - a disinclination to work or exert yourself
slothfulness
disinclination, hesitancy, hesitation, indisposition, reluctance - a certain degree of unwillingness; "a reluctance to commit himself"; "his hesitancy revealed his basic indisposition"; "after some hesitation he agreed"
2. sloth - any of several slow-moving arboreal mammals of South America and Central America; they hang from branches back downward and feed on leaves and fruits
tree sloth
edentate - primitive terrestrial mammal with few if any teeth; of tropical Central America and South America
Bradypodidae, family Bradypodidae - a family of edentates comprising the true sloths
Bradypus tridactylus, three-toed sloth, ai - a sloth that has three long claws on each forefoot and each hindfoot
Choloepus didactylus, two-toed sloth, unai, unau - relatively small fast-moving sloth with two long claws on each front foot
Choloepus hoffmanni, two-toed sloth, unai, unau - a sloth of Central America that has two long claws on each forefoot and three long claws on each hindfoot
3. sloth - apathy and inactivity in the practice of virtue (personified as one of the deadly sins)
acedia, laziness
deadly sin, mortal sin - an unpardonable sin entailing a total loss of grace; "theologians list seven mortal sins"
Edited by Flynnn
^Sounds very silly obviously. Most likely people are trying to get what they paid for them back when they were the majority of 250's on the market or the value has stayed high because of the original worth. There's no way they would actually sell for that much. Kwaka 250's are just as good if not better considering the km's. Plus you can put an Akrapovic on them :worship:
Praying rain doesn't fall over Phillip Island circuit tomorrow... Just that little bit of land... Please please please. Friggen bleak forecast for the next two days :(
rarity like all things aging from the 80s
Oh and watched the movie Warrior today, quite impressive i thought
They don't seem rare enough to warrant paying the same price for a bike that is 20 years older...Scratch that off the list.
Late model Ninja is looking like the go..
No idea what an Akrapovic is, but I wouldn't buy a 20 year old bike unless there was a substantial saving to be made, which going by bikesales listings, there isn't.
Not too convinced on rarity Ash... I mean, there are heaps about and they weren't a remarkable model, most are now in poor condition. RVF/VFR400 are more the 80's catch. But you could be right.
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 🥲 But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
