We get it man your car is like so totally fast nothing could ever keep up
For most people though its not just about going fast ie comfy ride, plush interior etc
Was talking about the gearbox bud. Back to your corner
Pull your head in Alex it's happy holidays in this country now!
f**k that! This is my country mother f**kers
Merry christmas
its been Merry Christmas for centuries. its a pretty f**ked up world if people want to change it now.
Come at me Muslims
pack of arseholes, the lot of them
GREEN P'S IN 8 DAYS
Aircon will cost me $3k + install, which shouldn't be much with my mate doing the electrical and his mate doing the plumbing
Bike would cost me $250+$250 in licensing, then $4-5k for the bike, $250ish in rego, $1k-ish in gear
Would be out riding it and wouldn't need the aircon on...
hmmmmmm
Need both
lulz at comparing the two :P
Do both :thumbsup:
Not just the quickness, but yea want to keep the car for ages and will be working in the city soon - not to mention people already replacing stock clutches in the manuals
People might say auto is gay, but when you drive a ZF auto they are pretty awesome :worship:
I will purchase a fg2 turbo with the ZF box one day with all options ticked.... one day... when they're much cheaper. Really love my cars low down 2000-3000rpm torque out of the corners, can only image what it'll be like with fg's 550nm 270kw
You should change your head lights and front bar to series 2. Saw a whole heap of fg series 2 xr's packed at Avis today, really want one bad..
