Manual LSD might fit auto. Final drive ratio may differ - you look at build plate for ratios should start from RC, manual will be RC41, yours would be RC43 I'd imagine.
mines got the GTT diff.
just want to fix it and put it up for sale. want an e39 530i :)
happy new year kunts
good weekend at Anglesea
played beach cricket yesterday with Steve Alessio and his kids at Anglesea beach. didn't know who he was till my brother told me. massive bloke
looking forward to sleeping in my full sized comfy bed in my insect free cooled down room
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
