From what I know, you can't store more than one map in the ECU, I think Hamish carry laptop containing both 98 oct and E85 tune and transfering via PFC datalogit.
I'm sure Hamish will correct me if I'm wrong.
data logit wont work on a mac i dont think... fek..
go kill yourself kadir.
Can't switch tunes on PFC, need Data Logit or FC Hako - Paul will tell you more about this, or Google it. Be surprised if it doesn't work with Mac. Or just shell out $200 for a small/cheap laptop...
Yes. Just beat my PB at the Island from April by .5 of a second after being set back by a traumatic crash in October. In an exhausted state as well!
Now down to 1:46.3 oooooooh rah! Only ten more seconds to go :D
Congrats, maybe it was me and the supplements :P
Yeah, I think one of these macbooks with intel core can run mac/windows xp.
Might be a option.
BTW, is this at Dromana on the pics?
yeah you need winblows to run datalogit
and fc hako is a cable only solution, so you use the fc hako cable with datalogit or apexi's software
again all windows based
you could buy a crap old dell lattitude laptop off ebay for 200 with a true serial port and run win98
many people do that for car based serial connection thingies (i sold my datalogit kit with a dell win98 laptop)
cool thanks..
i can install windows as a secondary system on the mac..
will i need the datalogt module to use it? or is it just a pfc to usb cable??
yep you can try running it inside an emulated windows
as long as it can speak to a serial port it should be fine
datalogit expects a serial port, and doesnt understand usb
so as long as whatever you use, appears as COM serial port, it will work (or should)
datalogit is software and a cable
fc hako is a cable
depending on what software you try to use, will determine what cable you use
or vice versa
if you have an apexi legit cable, you must use their software
if you have datalogit cable, you can use datalogit
if you have an fc hako cable you can use any software
grant
as long as it (the pc or laptop or mac or windows or linux or solaris or beos) can speak to a serial port it should be fine
datalogit (and the others) expect a serial port, and don't understand usb
datalogit ships with a USB cable and so does FC hako
but all that this cable does is provide a USB serial port
datalogit and apexi fc pro etc don't know native USB speak
they just assume its a COM serial port and hope for the best
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
