what does everyone think of USDM styled cars
shit... like everything the yanks take it too far in some pathetic attempt to beat everyone else in something that is not a competition
What is usdm exactly? Looks like jap cars with euro/jap wheels on them..
Would usdm refer to us made vehicles?
technically yes, but as far as styling goes, usdm is essentially fatlace inc
Yeah I know you know what it means, but even JDM doesn't mean anything, people use it as if it means Japanese development motorsport to make themselves feel special about owning an import, but it's like calling a silvertop taxi ADM....
yeah, it does... it mean's Japanese Domestic Market.... just as USDM is United States Domestic Market
the term actually refers to the original country the car was delivered to :)
So my girlfriend was at my place...Walk her out when she was heading home, wearing nothing but a pair of shorts. Once outside I noticed how chilly it was where as inside was still quite warm, hence the lack of clothing...
Closed the door behind me so no flies/insects would get in...Wave to her as she drives down the street, still cold but it's rude to go inside before the person leaves...
Turn around to open the door, locked. Phone inside, keys inside, clothes/shoes inside...
Quickly run down the street in the dark, barefoot (quite painful) trying to catch her, but unfortunately for me she isn't a slow driver.. Then had to run to my brothers house, still barefoot and shirtless obviously. Thank f**k he was home or it would've been an hour or so walk to my parents house, again, barefoot and shirtless...
Eventful end to my birthday..
Edited by Flynnn
Thanks, I know all that and wrote it above. Point was that shit like 'JDM as f**k' means f**k all.
People use JDM as if to refer to the way the car is styled (good offset/stance etc), but the 2 have nothing to do with each other \
This is 'JDM as f**k'
ADM as f**k
USDM as f**k
There is something about yourself that you don't know. Something that you will deny even exists, until it's too late to do anything about it. It's the only reason you get up in the morning. The only reason you suffer the shitty boss, the blood, the sweat and the tears. This is because you want people to know how good, attractive, generous, funny, wild and clever you really are. Fear or revere me, but please, think I'm special. We share an addiction. We're approval junkies. We're all in it for the slap on the back and the gold watch. The hip-hip-hoo-f**kin' rah. Look at the clever boy with the badge, polishing his trophy. Shine on you crazy diamond, because we're just monkeys wrapped in suits, begging for the approval of others.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
