Not exactly smoothly, I struggled yesterday with a/m coilovers to stock, surely I'd learn the next day but for some reason my brain didn't work properly...
After couple of beers, it helps a bit, all sorted, tomorrow morning will drive around and see if i can adjust the dampers at rears before putting all seats back in.
lol good to hear the beers helped! :P
Doesn't matter what they were.
No point giving him any credit/attention.
He PM'd me from one of them trying to give me some spiel about a whole heap of "facts" he thinks he knows about SAU.
I LOL'd, then banned that one too.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
