nope hence why it should be interesting lol
was supposed to do that but told em i'm only free 1 day a week etc and they let me do the one day deal
There are after hour multi day courses available that can be spread apart for convenience.
Up to you if you think an extra couple of days will be useful.
Full time work - Day 1. On time, stayed awake all day. Great success
I'll give you 3 months before you become a zombie and a slave to the system...working jobs that you hate...for that shit you don't need...it's too bad...the world is based on greed...
Welcome to the rest of your life
Its good earning the money, but sad when you realize.. fark.. this is it. this is life. lol
would be better working 4 days 3 day weekend.. should be the standard imo. ;D
You'd only use it on a hot day or a cold day when not raining.
I want one, where can you get it from?
The only problem I can see with that is there is no Parker. :S
http://www.rhdjapan.com/silk-road-section-headlight-intake-kit-r32-15821
It has parker, i think its the ring around the main driving light.
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Lightly sand back, spray with primer, wet sand the primer, prepsol the surface and then spray with paint. Success! Also...you can use a trigger hose these days :)
This...used to work 4 days a week and it was the best balance between work and leisure. Was so much happier overall with the extra day, and got so much extra stuff done too :(
The money difference isn't that bad either...just that most jobs/careers don't work with only 4 days a week :(
Lightly sand back, spray with primer, wet sand primer, spray with paint. Success! Also...you can use a trigger hose these days :)
i did sand back to metal, primer and spray paint...guess i missed out on the wet sand primer..le' fu~
Also do very light coats of paint and wait for each little spray to dry...even if it takes you 15 minutes to paint them...that way you create layers to reinforce each other rather than just one layer of paint that will flake off all at once. Also prevents runs.
Spray at room temperatures and not in direct sunlight or too far away, otherwise the paint dries before it hits the part you're spraying.
Painting takes a long time to master. I even know how to do it and I still can't do it properly lol.
bah, i'll give it another shot when it all flakes off. Dont have the patience for it haha
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
