That is what stopped me from buying MA61 and MA70 Supra back then, read too many stories about them blowing h/gasket.
Okay just messaged my mate and he said, what you said is true.
But you just need to get the head resurfaced and possibly block, run a cosmetic steal head gasket and some arp head studs, and then it should hold well after that :thumbsup:
thinking about it.... but see below post
hardcore/cheap/lazy
Ah fair enough.
Excellent, I know something about 'yotas....
Now that is sorted.
kgo.
Need Panasports and it'll be fap-worthy.
SAU is not a vicroads authorized club for club permit scheme,
and I cannot see this changing as there is not much need considering most ppl's cars here are not more than 25 years old.
I don't think you'd ever want most people cars on club reg, too much headache.
Given its two years til r32s become eligible, now is probably a good time for SAU to sign up with only a handful of people wanting club reg, easier for the club to come up to speed with all the requirements.
I'd be worried if the gasket was cosmetic :P
Grant/Leigh - thanks
Fun riding a bike? First time?
Yea first time. They made me start on a scooter which was a waste of time but good fun. Then got me a bike, was trickier than I thought, stalled it couple times but got the hang of it by the time they started testing. Definately going for 1.5 hour courses to practise gear changing before I go out on the road.
yeah. please do. so i know if i do get one. how much i'm up for.
doing research before another potentially stupid purchase...
Normally your looking at about $2k-2.5K parts and labour including cleaning, checking and resurfacing of the head.
Though I'm sure you have chit chat with him and talk specifics I'm sure you'd be able to make a deal with him ~$1.5K for the job.
My bad... though..could go Cosmetic as they say Maybelline because you're worth it
Edited by blah_blah
Hahaha scooters are underrated. Good idea on the practice sessions, better to get these things downpat, one less thing to worry about when you get out on the road with cars. Everything becomes second nature very quickly.
hi, i have a t5 out of an xr8 that has a possible snapped input shaft.. will you still take the box? this is the only damage.. no cracks in the housing etc.... if you will would it be a lower price etc? i am in south as. can you give me a close price..?
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
