good deal who with?
Rider bros at calder park
I emailed them about the 2 day course but she told me that they believe it's a waste for 90% of people that they get their...So booked the one day course on my RDO, works perfectly.
The other joint I was planning to do it at the weekend just gone (they cancelled the course due to lack of numbers) would only let me do the 2 day course (because I enquired about that initially, they knew I was a beginner so wouldn't let me do the 1 day course)
Rider bros said that they find the 1 day is fine as the extra time out on the bikes is far more beneficial than sitting in a classroom...makes sense to me
Michael,
To be completely honest with you we find the two day courses are unnecessary
for at least 90% of our students, regardless of whether or not you have any
prior experience on a Motorcycle or Scooter. For the reason that we find our
student’s two wheel awareness will be increased much sooner by spending as
much time as possible out on the bikes/scooters, rather than in the
classroom.
The one day Learner Permit course is designed for people who have minimal to
absolutely no previous riding experience. This course can be completed on
either a Motorcycle or a Scooter between Mondays and Thursdays with a start
time of 9.00am.
Motorcycle or Scooter, the course remains the same for everyone as it is the
same Learner permit. You are required to successfully complete two tests on
the day, one skills test the other a written test consisting of 32 multiple
choice questions. This can be completed verbally. For the written test it is
essential you grab a copy of the VIC rider handbook and have a read through
it prior to your course date. You will find this book at your local
newsagency, VIC roads office or via the VIC roads website.
To complete this course on a Motorcycle the cost is $270.
To complete this course on a Scooter the cost is $240.00.
Costs include ALL VIC roads fees, issue up fees etc.
A Motorcycle/Scooter, Helmet, Jacket and Gloves will all be provided for you
on the day. You are required to wear full length pants and sturdy shoes.
Thongs, sandals, heels, shorts, ¾ pants etc will prevent you from completing
the course with us on the day.
With all our courses you are offered a free re-test if necessary. As part of
our trainer guarantee we also give you the opportunity to return on a week
day for some extra training (again at no cost.)
Do you hold a current Victorian driver licence?
At the moment you need to book about a week in advance.
Cheers,
Sarah Rider.
Rimon just make sure when you do go on the road you start off riding around some normal 50k streets / carparks until you get comfortable.
Even though I had ridden dirt bikes before, when I picked up my road bike from peter stevens in ringwood i hopped straight on eastlink after riding 50meters.. was a bit scary seeing trucks right up close flying @ 100k's for my first road ride haha
Birds - do you build many ZF 6 speeds? worth getting stronger input shaft when pushing ~400rwkw?
And try not to do your first ever hill start on a busy (wellington) road on your first ride after picking up your bike :/ wheely stalling fun to be had
Hey guys looking at buying a new alarm.
After something pretty decent because of a couple of fairly decent attacks on my car recently (attempted break in, smashed front windscreen, mirrors broken off) and was wondering what people recommend. Tossing up between a cyclops with microwave, tilt and shock sensors or a mongoose Rav3. Any other recommendations? Or thoughts?
Cheers guys.
Something with blackwire and to Australian standards. I have a Viper in my car it seems to do the job. Has glass break sensors, wheel sensors, 3pt imobiliser
Might sound stupid but I thought that viper alarms weren't ADR complianced?
Correct me if I'm wrong because that's the reason I hadn't bothered to look at Viper
All good, hows the r1?
Still scaring the bejebus out of me, but I do push the throttle and RPM a little bit harder with each ride. Thinking of putting a sprocket set on it, as redlining at ~165km/h in 1st gear is not very practical. By the time you're in the engine's happy range (~6000rpm+) you're usually at the speed limit. At that rate I'm not going to last on my option notice. What does 1st take you to on the GSX?
lol, use the footbrake for hillstarts!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
