Degree in Accounting is required :P
I actually prefer working as opposed to studying.
As once work is finished its shut off the mind and relax, uni its constant assignments and studying.
Making money helps also!
I hate you tony
The maccas guy went a bit hard sure defend yourself but beating em when theu are down like that is fkd up.. Two women no less
Although the maccas guy is a convicted murderer so not a huge surprise eh...
That I'm an Accountant? Nothing to be jelly of brah
Im sure there are a lot of people who would enjoy going to work and sleeping lol
as Alvin said, this is what happens when you get dickheads that walk around thinking they own the world. they mess with the wrong fellow, get beaten..
Im pretty sure a few pages back this is what everyone was trying to tell kryslu or whatever his name is?
Yeh the women are out of line no doubt but U don't beat girls he was clearly bigger than em... One of them got a fractured skull n broken arm
that's why he was put in jail for manslaughter in the first place. probably has impulse issues.
they just messed with the wrong guy this time...
no sympathy though.
Wish I could take my car for a spin!
what you getting done man?
Glad it's filling you with the joy.
ahaha certainly is! :D
been clay baring and detailing it mainly, but even that's been fun!
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
