Hmm the Megelli 250R looks even better than the Ninja... None for sale second hand in VIC though...$6k for a new one
http://melbourne.gumtree.com.au/f-megelli-All-Categories-W0QQKeywordZmegelliQQisSearchFormZtrueQQlsiZInConfigQQlsnZMelbourneQ20Region
read a review about them. sounds cheap and nasty
got pulled over in my mates EK civic on brunswick st last night after he decided to rev dump and spin all of first.
cops proceeded to f**k with us saying we looked like drug dealers and then cracked gay jokes lol... kunts gave it to our lives... THIS IS AFTER they made us turn out our pockets and searched every thing in the car. went through my wallet and stopped halfway and looked at me with a concerning look and goes. hmmm you lied when you said you had nothing... lol kidding
dont like how the seat lines up with the tank...
adding kawasaki zx2r to my list
90's 250cc's is where it's at, all these new ones look meh
imo
I always see an R15 at trade school...Looks pretty small so might be a 250..
They be 150s. Lots of 150s look good, shame about the size though. Aprilia RS125 looks like a fun little bike.
just a quick q just brought a vs n looking to get 20 inh rims for a vs just wonderong if u sell the parts for the gearbox for rims to be rwc . or do u just go to holden to do the work im a bit in the dark about it
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
