Would be good if the power FC was like the cappa flash tuners that way you can store a 98, e85, valet tune and not actually get pulled up on it by the cops because it still only flashes the factory ECU so you don't actually need anything plugged it
inb4 fords are gay, bikelineaustralia etc.
Since this thread is now run by crotch rocket enthusiasts.
Compared to cars, how expensive/cheaper are insurance on these things?
Generally cheaper, but what car and what bike are you comparing? My R1 is ~$800/year full comp, plenty of cars cheaper than that, plenty more expensive. Also plenty of bikes that cost ~$1400/year full comp and plenty that are ~$400/year. Plenty.
Cut up standard ECU, cover PFC in standard ECU housings, use a laptop to switch tunes!
I didn't want to cut up my ecu, so I just switched the covers on the pfc front to back, so the big apexi logo faces inwards. Put the Nissan sticker on the outside of the pfc, done.
Inb4 hwp
Birds, say your GTST and R1.
Both cost me ~$800/year full comp. Just pick a bike you like and do an online quote with a bike insurance company, that will give you the best idea. There are too many variables involved.
Inb4 hwp
Good idea, might try that.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
