Can't generalise bike models either, "over-zealous" riders don't really conform to a particular make/model. Car cruises are a bit different if they are organised by an official club too, cause then you have a registered non-profit company that can be held liable for public property damage if people do stupid things. Try suing a FB group lol.
one of the guys from autobarn's cars was nearly stolen at work the other day... (white 34 gt)
some guys came into CHADSTONE (not highpoint) and smashed the window, removed the igition barrel and tried to start it. they failed so they just took everything they could carry. they also stole a black 34 from the same carpark!
this happened just 10 car spaces away from the shop and in a FULL carpark
needless to say i locked my car in our garage and wont be driving it to autobarn anymore!
try drilling them out? if its possible
one is possibly drillable, though one is not as its spinning which means the nut inside the wing is freely moving also, i might give the thread doctor a call tomorrow
Edited by bluejeans
Anybody have/know of someone selling an ECU for an R34 GTR?
Also need a stock frontbar...or I could fix the old one I guess. Looks bad though.
pretty sure Scott has a power fc
finally got my wheels on.
look siiick bro. gotta lower it more though
pics
