True, FWD is going to be interesting, and yeah depends on the potentiality of the engine too.......I quite like the interior though - the NA version, for its price has a lot of extras that one would find in a car worth twice as much (even paddle shifts! :banana: ).....but, I find that Hyundai have come a long way in the quality of their cars.....
Don't mind the look of those Velosters in real life. Got excited when I heard there was going to a turbo model...this was Hyundai's big chance to do something good in a sports car. But FWD, ~$35k, 0-100 in 7.6-7.8...son I am disappoint. Unless that engine has potential the 86 or GTI is sounding like a better option.
I could live with the FWD, but the acceleration is a deal breaker for me. Golf weighs 100kg more and has only slightly more torque, but is basically a second faster. Dat DSG gearbox...
my n/a 33 manual stripped out car was so much fun, healthy engine and hammered! no lag and all fun was so happy with it on my Ps
these days i'd go for a GTI if i could afford it (you can drive them right?)
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
