The other day on the way home from work this Asian bloke fell asleep opposite me (like sound asleep / snoring).. I woke him up at Box Hill.. (like accidental knee nudge) I just assumed.. and he jumped up and ran out before the doors closed - Is that racist or helpful?
It would only be racist if he didn't get off at that stop. Lucky for you.
ikr. Antonio Tran
Antonio Tranetto is my full name
The DVD players were purchased legally.
There's no way you paid for what's under the hood of those cars by doing tune-ups and selling groceries.
Whatever it is you're in on, I want in on it, too
need to bitch... selling re30s on ebay for 1800
Dear xalmon,
Hi take them of u for 1200 today
- minhtamy2j
Dear minhtamy2j,
when you have a genuine set of re30 for sale at 1200$, i'll get 5 sets please.
with your budget, maybe you should look at rotas? oh wait, with that budget you wont even be able to afford rotas. try harder mate.
- xalmon
Dear xalmon,
Lolz I just bought ur one on forum for 800 bucks with tyres . Good luck selling it mate
- minhtamy2j
he lowballs me,
i reply.
and he says he's found another set of re30s for 800$? 800$ re30s? i'd like 5 sets of those please. all in just 10mins.
my jimmies have been rustled.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
