good good man!
we had a scare the other day as we had to go to the hospital for an unrelated matter (she hurt her shoulder at work) and we got a call back cos some scumbag that was at the hospital on the same day had german measels.
that was a week and a half ago and she didn't get it thankfully!
it turns out that the immunisation we had as kids doesn't last for life as was previously thought and you need to get booster every couple of decades :/
my jimmies were fairly rustled, but now no tears
when i ordered my black XD9's they were paid for in december and in MARCH we called and got told they were being made that week.
(satin black is made to order) needless to say order was cancelled lol
Wheels still not here after 14 weeks, told it would be 6-8.
Jimmies status: heavily rustled.
lol 6-8 is the guesstimate for everything in week form. International shipping? 6-8 weeks. Broken bone? 6-8 weeks. Embryogenesis? 8 weeks. 2 months wait for a new release game? 6-8 weeks.
HAHAHA sucks to be Moh.
So, going back to the old system plus another 5kw/tonne...does this mean that the R32 GTS-T (or was it the R33 GTS-T?) will now just scrape in as P plate legal?
good good man!
Yeh bloody Germans.. Nah it's good to hear its all going well. And don't give your kid anything to do with moh
if you read it has to come with a VIN plate stamped with power/weight.
so still no go on older turbo's.
Nah thats only from new but IDE assume they'll have a list of the cars that fall under the power to weight but still be restricted, like skylines
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
