i agree, but id still want something like that lmao
dudes, my rb20 turbo off my dead engine, stuck my singer into the intake where the impeller is and felt an edge, like its been machined, this normal? pat?
You stuck your what into the intake? Wait... I don't want to know the answer to that haha
No idea, a hi flow rb20 turbo would only get you 200kw. Although responsive it would give the same power as a stock rb25 turbo.
Had a hiflow rb20 turbo but didn't bother fitting it, rebuilt a hks2530 instead
would want to make a responsive 320kw on low boost for street and 400+ on high boost for track later down the track.
With the amount of attention to detail and work which you are putting into the car, the last thing you want to do is slam it into the wall because of an oil spill on the track (happened to my friends restoration car)
You decide now; is it a track hack with no care for panels or a Clean streeter? The choice you make now will save you heartache in the future.
lol wrong way round mate... your track tune is meant to be the one with LESS power
try driving 300 before you decide on 400 lol
lol true... 3oo at the rears is one hell of a drive in a 1.3 tonne car that knowing moh will be low and stiff.
dont get me wrong, i LOVE my car and it's 3oo rwkw however it's not something you need lol.
i'd be happy with ~250 in a car that weight and you could wrangle a 20 to get that
driving a 3.0 with 300+ is basically just a controlled crash from the moment you touch the accelerator
id probably cry if i crashed it...
:/ what i dont even
i kinda want to continue the GTR look, and drop a 26 in it... dont want it to be a 4 door 32 thats just had guards put on, if you get what i mean
im not going bellow legal on this..
id be happy with just a stock 26... but the 30, is more of a why not..
Well said...
That's what I'm still deciding with my R33: track basher and let it go au naturale, or fix the hail damage with a full respray and keep it nice. Either way, my wallet loses.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
