i agree, but id still want something like that lmao
dudes, my rb20 turbo off my dead engine, stuck my singer into the intake where the impeller is and felt an edge, like its been machined, this normal? pat?
You stuck your what into the intake? Wait... I don't want to know the answer to that haha
No idea, a hi flow rb20 turbo would only get you 200kw. Although responsive it would give the same power as a stock rb25 turbo.
Had a hiflow rb20 turbo but didn't bother fitting it, rebuilt a hks2530 instead
would want to make a responsive 320kw on low boost for street and 400+ on high boost for track later down the track.
With the amount of attention to detail and work which you are putting into the car, the last thing you want to do is slam it into the wall because of an oil spill on the track (happened to my friends restoration car)
You decide now; is it a track hack with no care for panels or a Clean streeter? The choice you make now will save you heartache in the future.
lol wrong way round mate... your track tune is meant to be the one with LESS power
try driving 300 before you decide on 400 lol
lol true... 3oo at the rears is one hell of a drive in a 1.3 tonne car that knowing moh will be low and stiff.
dont get me wrong, i LOVE my car and it's 3oo rwkw however it's not something you need lol.
i'd be happy with ~250 in a car that weight and you could wrangle a 20 to get that
driving a 3.0 with 300+ is basically just a controlled crash from the moment you touch the accelerator
id probably cry if i crashed it...
:/ what i dont even
i kinda want to continue the GTR look, and drop a 26 in it... dont want it to be a 4 door 32 thats just had guards put on, if you get what i mean
im not going bellow legal on this..
id be happy with just a stock 26... but the 30, is more of a why not..
Well said...
That's what I'm still deciding with my R33: track basher and let it go au naturale, or fix the hail damage with a full respray and keep it nice. Either way, my wallet loses.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
