Lol so I've bought a gtx3071r and estimating around 300rwkw. I probably will kill myself, but I don't think it will too as responsive as yours with 300kw for say. Should be fun
definately not considering a 3071 .86 is less responsive than mine on a 2.5 anyway let alone a 2.0 ;)
Yeh going on with a .82 to begin with because it's there. But might go .63 if it isnt responsive enough
stock 26 + n1s and a tune?
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint after high expectations. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
26 isn't that good man...I drove one the other day with the same power as my 25, it wasn't any less laggy getting on boost. Left me disappoint. Whatever cool, original shit you want to do with your car engine wise...it's all been done before. People have put 1JZs in Skylines lol. Just do the most practical and cheapest thing that most people do and junk a 25 in there.
A 25 neo would be good will have some transient response with the variable timing too!
this.
Anything wrong with buying a 2nd hand bike jacket assuming it's in near new condition? Let's say rrp is ~$1k and I can get it for less than half price
Or for the same price get something not as good but brand new?
/bikes
Couldnt see a problem with it as long as it fits and is in good condition
What jacket is it?
Oh then what's the diff between neo and 33 liner?
Just get a 25 moh out of all people I don't think YOU would notice the difference in 100cc lol
R34 turbo has a bigger rear housing and something else ECU related I think.
/bikes
Nah that's fine, it's not like buying second hand helmets. If it fits go for it.
/bikes
oh thank god. i was starting to think this forums was about skylines.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
