yes it is a very pretty bike, I like my girls to be pretty too, but a machine is machine, and a machine is like a man, it has no need for makeup
So you see, riding that bike is like wearing a dress, in comparison to driving this monster :P
^ lol
birdz ride tonight? :) if the roads dry up.. :(
They won't be dry by then, well not in the mountains anyway, which is where I'd want to go :(
Plus I'm hitting the clubs with three beautiful ladies :)
EDIT: it's still pissing down too, lol
the difference? i'm not in monash.
and i'm doing process, so, nothing big to draw. =D
touche.
guys a right about the weather though... so dreary. got out of my exam at like 6 and it was so dark out already!
i guess you might even say... WINTER IS COMING...
well that "dress" will most likely destroy your manly, make up - less machine anyway so might aswell look prettyfull ^.^
ah pity the foo
not in this case i'd imagine... i'm all for bikes being faster than cars, thats just fact, but you get to a point where bikes can't keep up
i'd imagine that in a drag race there wouldn't even be a race - that dont look like no 11 sec car lol
Ultimately four wheels are better than two, but some of the yanks get their Hayabusas into the 8s with relative ease.
touche.
I'll give you a red smile. From ear to ear
^^ LOL! WUT!
Yeahhhhh
I'll roofie the jailbait...
lol i wont be at the next nats, so no steak, and no chartreuse.
Damnnnn that weekend was a laugh.
Haha and now we have top bloke moh lol
Doesn't mean ill rape you Aaron, you'd just be terrified when you wake up.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
