Haha how slow do you have to take the corners on that hill...so damn tight. Gotta slip the clutch in 1st on some turns :/
Haha i know some of them are like wtffffff up and around really tight 1st or 2nd gear for me
lol @ that phaggot
Leigh what's done to the xr6?
not sure, good thing is the 4lt means you can pretty much strap on what ever turbo you want.. crazy
lol
wtf do you do for a living?
I'm a system engineer, (Although returning from NZ I'll have a new job which is like a commissioning technician role)
Hump is growing on me...
lameeeeee!
I will be missing in action over the next 2 weeks guys off to NZ for a holiday!! (leaving tomorrow morning) :)
Ordered new front and rear fender, front light, and rim tape hopefully delivered while im overseas :D
Gonna miss my baby: :(
need to meet june 24th dead line, bride copy will do.
lol what are you on a car building reality tv show?
lameeeeee!
Give it a couple of years, most jackets will come with them and it will be a minority that don't have them lol. I wouldn't have one on a commuter/cruiser/motard, but if you're hitting the corners on a speed machine you will look the part.
Sucks man, I was going to hit you up for a ride on Friday cause I have it off!
R1/R6/GSXR/CBRRs I can understand, but if you got a 250 / cruiser / motard then yeah I reckon a bit lame as they wont get any decent speed anyway lol
ride in 2 weeks time :D you can come over and help me put on my new parts if they arrive :P
I was reading up on them earlier, apparently they give more protection than they do aerodynamic assistance. Some manufacturer did wind tunnel tests and found little to no aerodynamic change, whilst people have been in crashes with them and claimed that the hump levels out your back with the back of your helmet - therefore less pressure on / chance of hyperextending your neck in a fall.
Yeah I'll give you a hand.
i've never fallen off my car...
~jussayin
I'd happily have the hump if im riding an R1 lol but on a lil 2fiddy looks a bit overkill
Aparently makes a noticeable difference on freeways/high speeds
Some find it uncomfortable though
Dez what jacket you getting?
Something in the Dainese range
ill try this again as i accidentally posted in vic post your ride thinking i was in wasteland >,<
parts left japan on monday according to rhdjapan and i come home today and they have arrived :S
thats faster than aus post can do from syd -> melb!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
