Yeh I should be constantly checking the email sent to junk shouldn't I. Lol no point in junk then isn't there..
Sif I wouldntve renewed if I knew though. I love SAU bro I just Love it
All sorted.
Now you owe me a 10sec car
All sorted.
Since when did you become a VIC Club Executive Member?
ayo dezzmang/ other old schoolers.
you guys know a dude that had a 32 gtst + s2 rb25 on here from fawkner named colin? hes a ranga lol
hes on sw, knows all the old school sauers
What's his SAU username?
Looking good, front fender looks much better. Meant to reply to your other post and say if you need a hand I'm only free after 7:30ish...
haha all good
front fender is way shorter when you compare them side on too so much cooler :D
on another note, i have a new awesome mx style helmet and these awesome goggles.. was waiting for a friend at nandos when these 2 fine ass personal trainer looking girls walked past in their training costume.. didn't know what they were looking at and I just shrugged as they walked off I overheard "wow that's an awesome helmet" to the other girl, do women like matt black?? never got that attention with my other helmet lol
What you in charge of?
LOL! I just noticed your Executive tag today.
Yeah only got the tag last month
In charge of the financials of SAU VIC. To ensure it still exists when your children want to become SAU VIC club members :P
I see!
Awesome! Keep up the good work then :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
