rode around with a mate on a r1 the other day he's crazy we went into a dirt carpark @ the basin and he was ripping it up as well funny as seeing a r1 roost
Latte drinkin motherf**ker!
That is crazy, I don't like dust getting on my bike let alone that :@
Hahahahahaha, I hope you were being sarcastic there as Leighs instance is so far from 'cafe racer' 'latte' mentality and yours is pretty much perfect for the bill :P
Haha that's awesome. My mates a pro motocross champ and was hired as a stunt rider for the new Mad Max film. Showed me some pics he secretly took of the bikes. R1's with knobbies and super extended swing arms speeding at 200kmph on dirt tracks. Bikes had horse saddles as seats and covered in old number plates... All post apocalyptic in typical Mad Max fashion. Completely insane!
haha that sounds sick as when does the movie come out?
He got it brand new only a few months ago too :P crazy mofo already done 15,000 on it
oh snap!! it's true - Adam did your R1 come with a skirt? :P
still awaiting for our bikelineaustralia vic cruise, even if I'm the only tard
Not sure if serious...
He went and drank a vanilla latte...
No idea I think the filming was postponed for a while :(
That's rad, I had my Hyosung for 2 years and put 46000ks on it. Best times!
Wait for me! Hopefully getting a bike super soon fingers crossed. Weather isn't that great atm :(
At least he rides his bike more than he cleans it :P;)
Apparently the JDMST meet was shit, everybody started to try and one up each other. Lots of people hit the limiter upon exit and some retard tried drifting and smashed his car.
Also it was finished by like 4pm. Bunch of princesses in Melbourne; don't like cold, don't like rain
Glad I had work and missed out on this one. Anybody here actually go?
haha such a reboot of MCCR
this the sort of shit that kills things.
next time come to the track and do it in style
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
