rode around with a mate on a r1 the other day he's crazy we went into a dirt carpark @ the basin and he was ripping it up as well funny as seeing a r1 roost
Latte drinkin motherf**ker!
That is crazy, I don't like dust getting on my bike let alone that :@
Hahahahahaha, I hope you were being sarcastic there as Leighs instance is so far from 'cafe racer' 'latte' mentality and yours is pretty much perfect for the bill :P
Haha that's awesome. My mates a pro motocross champ and was hired as a stunt rider for the new Mad Max film. Showed me some pics he secretly took of the bikes. R1's with knobbies and super extended swing arms speeding at 200kmph on dirt tracks. Bikes had horse saddles as seats and covered in old number plates... All post apocalyptic in typical Mad Max fashion. Completely insane!
haha that sounds sick as when does the movie come out?
He got it brand new only a few months ago too :P crazy mofo already done 15,000 on it
oh snap!! it's true - Adam did your R1 come with a skirt? :P
still awaiting for our bikelineaustralia vic cruise, even if I'm the only tard
Not sure if serious...
He went and drank a vanilla latte...
No idea I think the filming was postponed for a while :(
That's rad, I had my Hyosung for 2 years and put 46000ks on it. Best times!
Wait for me! Hopefully getting a bike super soon fingers crossed. Weather isn't that great atm :(
At least he rides his bike more than he cleans it :P;)
Apparently the JDMST meet was shit, everybody started to try and one up each other. Lots of people hit the limiter upon exit and some retard tried drifting and smashed his car.
Also it was finished by like 4pm. Bunch of princesses in Melbourne; don't like cold, don't like rain
Glad I had work and missed out on this one. Anybody here actually go?
haha such a reboot of MCCR
this the sort of shit that kills things.
next time come to the track and do it in style
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
