anything above 3 is enough to put me off.
depends on whether they were relationships though.
casual sex. 1 is enough to put me off.
+11111
my ex hadnt been with anyone else. and wanted to wait till we got married(that was actually on the cards.. YOLO). fine by me. gotta admire women like that in this day and age.
but shes my ex, and the mental image of some dude ramming her if she went off the rails sickens me.
girl im seeings been around, but yeh, aint gonna wife her.
+11111
look i have to say it.
i am yet to see ANY of your ex's.
and a pic of you with them is necessary. not of just them.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
