still got your GTT stockies?
mind if i borrow them for a bit till my BBS' arrive?
thanks <3
yes you can, but the tyres are quite worn on those wheels, in fact, quite worn is an understatement.
I hope you are not planning on putting r34 gtt stockies on the r32....they will not clear the fronts...
Douchebag
lol. never knew that.
the hella ones? havnt gotten them yet.
they are the ones i bought. the ones in the car are stock and one of them sounds like there stones in it.
ah okay, was confused thought you meant the hella ones weren't loud :D
job interview tomorrow at ADT, wish me luck boys <3
good luck man :D
anyone know if there are any places which sell defi gauges in Melbourne? or at worst in Aus?
trying to grab an oil press gauge (no overnight parts from japan yo)
good luck man :D
cheers.. going crazy jobless atm!
My cousin owns a online parts store i'll see if he can get them.. I know there was talk of him beginning to stock them but thought most people were too cheap to buy them :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
