still got your GTT stockies?
mind if i borrow them for a bit till my BBS' arrive?
thanks <3
yes you can, but the tyres are quite worn on those wheels, in fact, quite worn is an understatement.
I hope you are not planning on putting r34 gtt stockies on the r32....they will not clear the fronts...
Douchebag
lol. never knew that.
the hella ones? havnt gotten them yet.
they are the ones i bought. the ones in the car are stock and one of them sounds like there stones in it.
ah okay, was confused thought you meant the hella ones weren't loud :D
job interview tomorrow at ADT, wish me luck boys <3
good luck man :D
anyone know if there are any places which sell defi gauges in Melbourne? or at worst in Aus?
trying to grab an oil press gauge (no overnight parts from japan yo)
good luck man :D
cheers.. going crazy jobless atm!
My cousin owns a online parts store i'll see if he can get them.. I know there was talk of him beginning to stock them but thought most people were too cheap to buy them :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
