saw this on fb.
also saw two brz's out front of autobacs in tokyo bay when i was there (i have photos somewhere). also another citrus coloured s14 like another resident of the board *coughaaroncough*
Aaron, estimation on how long it'll take to do two guards? Planning to keep the guard lining, but just cutting some out at the top.
Jeez your a slack flamin mongrel. Depends on how good you want it to look = how long I take
m8... give me ball park figure mun, i want it good, real good, just rolling them though, no flare.
Planning to go to yours after work on saturday. could be at yours at around 6-7~
Would be better during the day if u can. Should take an hour or two at max
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
