Impulsive overspending?
Just need to wait for those in brissie to wire me my monehh
you in the white powder business too?
do HotPot. defnitely good in winter!
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
Edited by Sunkist
Dropped car off in the morning to get some tint done.
Was all excite but just got a call saying due to demisters extending too much or something the tint won't stick to the rear window so it can't be tinted? :(. Said he hadn't seen this before :/. Taken pics so I can see when I go and pick her up, but yeah :/
Anyone else encountered this before?
Aaron would need to take off his front bar to get up alvins driveway. Think toby will be find as his is stock height?
I think my car is higher than stock height LOL
Could just do my house, 1/2 way between Aaron's and Alvin's house :P
Not sure, didn't have that problem when I got mine done...
lol then why does the guy want to lower his car? and lol you'd be suprised, my car actually does alright on most shitty driveways.
even better, albino can cook
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
your going to be wrecked that day from sandown bro
Yeah same day. I was going to do something later for my bday anyway.
Who knows might need a drink to drown my sorrows if something happens that day lol
Lol nothing's gonna happen dude. I might not join in on sandown. Allignment needs a doing and they said I'll need to flare my guards some more(traction tyres) with that and a retune plus cams etcs it's going to be an expensive exercise to only get kicked off for noise.. But will see what happens. Il definitely come watch
wasteland maf**kers, sat night, sept 1st, lagerfields at crown. going to be celebrating my birthday and shit and want you dream boats to be in on the shenanigans. ill have a penthouse booked so...... theres a place to KTFB
You bringing hookers to the penthouse?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
