Impulsive overspending?
Just need to wait for those in brissie to wire me my monehh
you in the white powder business too?
do HotPot. defnitely good in winter!
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
Edited by Sunkist
Dropped car off in the morning to get some tint done.
Was all excite but just got a call saying due to demisters extending too much or something the tint won't stick to the rear window so it can't be tinted? :(. Said he hadn't seen this before :/. Taken pics so I can see when I go and pick her up, but yeah :/
Anyone else encountered this before?
Aaron would need to take off his front bar to get up alvins driveway. Think toby will be find as his is stock height?
I think my car is higher than stock height LOL
Could just do my house, 1/2 way between Aaron's and Alvin's house :P
Not sure, didn't have that problem when I got mine done...
lol then why does the guy want to lower his car? and lol you'd be suprised, my car actually does alright on most shitty driveways.
even better, albino can cook
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
your going to be wrecked that day from sandown bro
Yeah same day. I was going to do something later for my bday anyway.
Who knows might need a drink to drown my sorrows if something happens that day lol
Lol nothing's gonna happen dude. I might not join in on sandown. Allignment needs a doing and they said I'll need to flare my guards some more(traction tyres) with that and a retune plus cams etcs it's going to be an expensive exercise to only get kicked off for noise.. But will see what happens. Il definitely come watch
wasteland maf**kers, sat night, sept 1st, lagerfields at crown. going to be celebrating my birthday and shit and want you dream boats to be in on the shenanigans. ill have a penthouse booked so...... theres a place to KTFB
You bringing hookers to the penthouse?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
