Ease up lads
Is it a full month behind or they are just overdue on the pay date?
We reminder SMS at 1 day late letter at 3 SMS at 5 and so on
Can i interest you in our property management capabilities?
Lol my real estate agent forgot to pay for insurance after I requested. Only realised 1yr later that there was no deduction...
i should be able to make it 11th.
i have 1.4kg of wagyu for slicing into hotpot thickness.
i can probably do one serve of singapore style chilli crab, of course, using mud crabs.
could also do some wagyu tataki. or something like that. can't think of anything else though, satay is too much work and requires a bbq grill. full 24 hours marination and shit.
Happy to host it if there is enough interest
Say 5-8 wastelanders brahs should be sufficient
You know what to get.
Lucky your mate's bet got refunded.
what a r1? :P
yeah I know right haha he said good that he lost or else he would of been thinking about 2.5k all day
I'm still a big motard fan, just like the fact you can go offroad and if you drop it practising wheelies not really a big deal compared to a 1000, also just rare you never see them around and people go wtf? lol
R1s are the sex still though.
hilux has arrived!
went checked it out today still needs to get all the extras fitted before we can pick it up hopefull by the end of the week
saw one of them 86 things at the dealership gotta admit it looked pretty good in person and in black. not impressed with the interior/dash though
that one's a lot of work involved. lol. but i could do a serve of that too.
haha it's ironic though, because you look at the two and you would think the chili crab (with all its sauce etc) would be harder to make :P
Guys,
I've got a bit of a horizontal crack on my tailight, anyone know what i can use to not let water get inside?
No sign of water inside but just making sure it doesn't get in.... was thinking some kind of silicon.
Guys,
silicone it from the inside if you can! will never see it.
or use some of that powder activate supa glue and wet sand /plastice polish till smooth.
Cheers Aaron! Remind me to give you a free sausage next time! :-D
hmmm... powder activate super glue.
Edited by Down_Shift
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
