Well so far being a member for a month or two and been to the last 2 months garage cafe meets, SAU vic execs are doing a great job. Not sure how the members section side of things are as i don't have access yet....
Just curious, who is this Ash guy? I still want my members access lol
Member section is dead. Nothing in there. All chat happens in this thread. Nothing to lose sleep over.
lol, i didn't mean it in a way to imply that you said anything negative about the vic commitee. I clearly understood what you were saying, chill brah! :spank:
Just wanted to voice my opinion on my experience so far with the vic commitee. :nyaanyaa:
Deep down Aaron is a big softie
Don't take to heart much what he says :P
lol f**k Precinct, line all the way to Punt Rd after 9pm and idiot bouncers who let in people with shitty runners on but not Timberlands/Colorados. Take your mates up Swan St for better pubs/hangouts.
yeah well I looked at all the modern cars.
86
GTI
focus XR6
none of them worked for me
so I thought I might spend a little less and get a fun car
so looking at S15 or 34 GTT
but damn, how cheap have 33R's got, so i'm thinking for a low KM daily why the F not have something fun!
so atm it a 33R or a evo6 TME
I had exactly the same thoughts as you. I was tossing up between the 86/BRZ and the GTI. But fairly certain I'll go for an 86/BRZ later next year. An R34 GT-T or S15 crossed my mind but they're a bit old and the fuel consumption of the R34 would be too crap for a daily again.
I'm not so worried wabout fuel usage as It will get low km
We will lease a nice daily something Like a tigran or similar that will be the main car and do most of the km. then a 2nd car for me for when I go in the office or run errands. so will do 3-4000 km a year.
So might as well have some fun.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
