I think you have to be an administrator to be able to give members' forum access to people, Ham.
Sounds like SAU Vic has started selling 86s haaaaah!
Yo look to the side when you're driving next time. Trying to wave to you on the Eastern last night, you prolly thought I was a cop in a white VE wagon lol.
Wtf that was you?!
The white ve Wagon was tailing me bad on the freeway, changing lanes when I did and quite close. Thought it was some bogans looking for trouble or someone I cut off or something haha
Was close to dropping back and getting behind the Wagon.
Paranoid much?
Go to another dealer
It was about a 12month wait via fleet
So buying it private should be shorter 6-12 months
Nah gg.
Toyota website says 18months too. People gone crazy for this car...
Interior was plastic and the dash reminded me of a hyundai Getz, I guess that's what you get for a budget car...
I'm used to the skyline interior design you can see a lot more money was spent but the car did cost more afterall.
Working on it! Weathers been shit so haven't been able to finish my polish :(
How long left in your probationary?
i see
still on L's dude
been too lazy gonna try booking for next weekend then i guess another 12 months of restrictions assuming i pass :/
yet to put L plates on my bike though lol f**k that
Wtf that was you?!
Paranoid much?
lol I went up alongside you and waved a couple of times, then resorted to pushing you off the road. Your peripheral vision sucks! Knew I'd have the cop look going on though, I'd have been para too.
yeah you do, but christian has told the admins that club execs are not to be mods, hence ash's hands are tied. i'm sure if he could ash would have at LEAST richo as a mod.
I didn't wanna say it, I think I've said enough
lol... dude the only person on the forum that thinks mad82 should be a mod is mad82. :rofl:
Gold isn't a light lol, it's just yellow!
Was considering gold levers but I think it's a bit much...they would really stand out and I'm going for a stealth look with minor gold touches. The shades of gold on different parts are also difficult to match; you can only really get away with small gold touches if the shades are different.
Lol Richo should be the moderator.
And lol
lol i see all. As the saying goes, if you dont swear once whilst driving, you are not paying attention.
Commodore tailing up behind me, then changing lanes, driving parallel and waving his arms then drop back behind and continues tailing.
Not sure if....shaking arms from a rage moment or a friendly wave haha
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
