You sure they're not CBRs they do look similar...
Saw an undercover motorbike pulling someone over :/ wasn't aware of their existence....
I saw that too the other day.
but they're bikes looks somewhat "Travel" like, right?
Just spent another 2.5 hours in Rimon's territory aka roof space. I love that shit now.
Lol did some roof work myself too today was in a new house though and very roomy :P
I see ALOT of spider webs in roofs even in new houses but never see the actual spider. 9/10 it's them harmless long legged spiders so meh
Come past mine afterwards, I'll be home :)
okay darling, spoke to the guy on the phone and agreed / he advised not to go for a balls to the wall tune and turning the wick all the way up hopefully a mild 350ish rwkw on his dyno (anything over i'll take as a bonus), still huge power some tuners go really aggressive with hem though but I won't just yet while it's still new..
lol the no lag thing is weird, compared to a laggy turbo car (ie my old GTR) that sudden rush of power I do miss.. but pulling skids in any gear is also fun :P and don't need to rev the crap out of it to go half quick. A v8 twin turbo would be my preferred balance :D
Aaron, you can never have enough power thought you knew this? :P
nah definitely 675's, they've got the badging on the fairings...
Yeah heaps of that around up there, but didn't see anything moving.. I've gotta do an exhaust fan or 2 at my place still....More room up there from what I've seen, but also had a rodent problem a while ago so not looking forward to getting up there...Especially when one of the fans needs to be installed about 2 meters from where I used to hear them the most...Should be interesting, hopefully they've all died and decomposed by now, and hopefully the smell is gone. Haven't heard them for ages so I'm confident they're all dead/moved out, but still likely to find some remains...
Hope you got some new tyres lined up...
Don't need new tyres when your fat ass weighs 1800kg.
Just pumped mine up...265/35 @ 33psi lol. 40psi makes such a huge difference to the comfort and handling.
Bunnings is the worst store to go and buy something specific; end up there for 2 hours browsing at other shit.
to the 86 dirvers, is the "awesome driving experience" simply because the thing is so underpowered that you just leave your foot on the floor and turn the wheel?
srs question...
my ksev was like that and to have fun you had to treat the clutch like rodney king
lol thats probably it. well balanced, low centre of gravity, rwd & foot flat in the corner. Probably feels a lot safer than a 350kw ford falcon doing the same thing haha
lol
where you putting em in bathroom/toilet? just run the wire from the light with a tongue/snake and save yourself getting up there
unless you want your lights/fans controlled seperately then different story...
lol
Yeah bathrooms, seperate switches for heat lamps/light/fan all in the one unit...
Don't know how you'd get a tongue from the light to the switch without getting up there though? please explain.
Whatever you're about to explain might work on a house that wasn't wired up by f**king retards, which this place was...Made a simple job a headf**k and a half
Don't be hating on the falcon :(, 350kw + pedders = leave a 86 for dead through the hills :P not as bad as people think in the dry at least
Put my engine in the 86!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
