As discussed you'd need to be big to pull it off, and because I'm built like a bitch a no no for me :P
Just had rare as f**k steak cbf waiting for it to cook more
rare on this scale tasted good though
lol well done - waste of a good qaulity steak..
fixed my dash made a custom surround with scott..
So now you'll be attending meets?
Bitch...
P.S. paint it black Aaron.
yeh ill be at garage cafe soon. wait for me yeh?
i was driving to scotts house holding the dash lol
Yo how come my Rode NT3 needs less trim than my Shure Beta 87A...both on phantom power...
different mic's dude. lol
the nt3 is a condenser mic it'll be less sensetive and need less trim than the 87A. plus phantom power is shite lol.. when you turn it on though does it buzz?
we use condensers for high hats or border line snare. plus guitars brass etc for when there isnt a DI or an acoustic is being used without a DI
No buzz from phantom power, sounds really good actually! 87A is incredible, doesn't even sound like a mic...just sounds like someone's voice coming straight through the speaker. And that's using my guitar amp as a monitor lol.
well it means that the mixer is earthed really well then so thats good.
yeh 87a is a great mic. you should invest in either foldbacks or some studio monitors.. did you end up getting them? cant be mixing through comp speakers lol play the track on your theatre system and itll sound aids.
lol reverb level: karaoke. Gotta work out how to put on reverb first; this mixer has so much shit to learn.
Will be getting monitors when tax return arrives. What did you recommend again?
it has in built effects in the mixer doesnt it?
i cant remember what mark thought, but i was thinking Behringer B3031A
DUDE, if you can get your hands on a set of yamaha ns10 studio monitors, that what we use. its also what tupac used and 808 studios currently use still.
but they are exxy
http://www.ebay.com.au/itm/YAMAHA-NS10M-STUDIO-MONITORS-/150879125911?pt=AU_hifi_system&hash=item232118c197#ht_500wt_1203
they arent powered either so you need another amp
but they are exxy
http://www.ebay.com....7#ht_500wt_1203
LOL @ ns10's in 2012
they were good (and industry standard) like 20 years ago man...
there is a lot better out there these days.
if you want a reccomendation give me a price range and i'll ask my brother (he was the audio project manager for the olympic opening/closing ceremony)
Dude ns10's are still one of the top studio monitors, if they are powered with a correct amp.
Live is very much different to studio work.
Yes i work in audio, and we have quite a succesful company in live & studio work. Birds can confirm this.
We use ns10m and im pretty sure if out mixes came out shit we wouldnt be where we are.
Anyone who says ns10m are outdated and shit, cannot mix for shit. And thats why they believe they sound like shit
lol i realise studio and live are different... i'm sure andrew didn't fill the stadium with 11ty billion reference monitors ;)
that's only 1 area of his job lol - poor kid gets worked to the BONE for like $75k (problem is he loves it)
Remember I was a dj/nightclub promoer and involved in studio production for a decade and have toured pretty much every major dance music producer (well the pre 05ish ones anyway) and eveyone has been phazing out ns10's since the early 2000's. we had 2 sets in our studio, and moved 1 set into the loungeroom. there is still 1 set in the studio that gets used for production, but not the final mixdown
ns10's are good reference monitors for production no doubt, but the reason for them being where they were in the industry was moreso that they dont have the best sound, and if your music sounds good on ns10's then it will sound good on anything.
if you want reference monitors for listening, then there are better options is what i'm saying.
you should hear these new ones that andrew bought man.... somewhere in ther region of 5k... they sound amazing
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
