If you come down my end. Borrow my timing equipment. Id be really curious what 80-120 your car would do and compare it to le` supercars
me? haha maybe ppl think it's faster than what it really is - not sure if disappoint now :(, I'm getting used to the power! surely 370 aint that much these days? :s it'll never have that 'throw back' feeling you get with turbos though I guess
I think birds has one of those timer things as well
Quality girl dezz, hang onto her.
We should put together one of those CS nights we talked about like 2 years ago.
Girl?
does he miss it
I'm down for some CS bring it!
Correct
New one coming out soon looks good
Lol yeah I was watching a vid of it on youtube right before I wrote that post..
Do some recordings on that private strip you own
Also riks gt3076 vs your ss1 i am also interested in
Rik (haha) will get me I reckon. Better rear tyres + 20-30 more rwkw. We'll do it though.
Was making a pun of your post.
CS2...hmm haven't heard of it, shows how out of the loop I am. Bet I'll still kick ass at it.
It's not CS 2, and I hadn't heard of it til tonight...It's basically the next step from steam from what I know (after watching a 3 minute video and that's it..) Basically just a new look and probably a slightly different engine...Still dust/dust 2/aztec/italy etc
As long as it has Office and shotguns I'll play it.
